Freenis B3014
robak1989
Freenis B3014
Post autor: robak1989 »
Witam odwiedzających.
Prezentuję dziś swój kolejny nabytek - Freenis B3014
Latarka zakupiona tu w cenie ~22$
Parametry ze strony sprzedawcy:
Kod: Zaznacz cały
Model:B3014
Emitter Type :Cree XM-U2 LED
LED Quantity:1
Lifespan of LED :10,0000 hours
Max brightness:1198 lumen
Max beam distance:300-500m
Light color:Cool white
Battery configuration:1x26650
Modes:High-Mid -Low-Strobe -SOS
Waterproof:IPX-8 standard
Casing color:black
Body :7075 Aircraft grade aluminum body structure
Reflector :Aluminum Smooth / SMO
Lens :Ultra-clear tempered glass lens with anti-reflective coating.
Premium type III hard anodized anti-abrasive finish,anodized thickness of 40 microns
Dimensions: 170 mm(Length);48 mm(bezel Diameter);35mm(Body Diameter)
Weight:240g (without battery)
the control switch with function of shift and low battery display
Freenis B3014 Flashlight Torch Cree XML-U2 LED 1198 Lumens use 26650 Battery
B3014Feature:
1.Industry "independent cooling section of the layer" technology,which is the best way to heat dissipation for torches and keep the U2 torch brighter  all the time.
2.Intelligent highly efficient circuit board design for max performance and long run time.
3.Intelligent temperature controlled light output for user safety.
4.hardware control light,no stroboscopic,no current sound.
5.Premium type III hard anodized anti-abrasive finish,anodized thickness of 40 microns
6.Memorial function for 5 brightness modes with memory circuit board, and Microcomputer chip control design :High-Middle-low-strobe -SOS, .
7.Reversed polarity protection technology for battery,it means if you mix the battery polarities  “+” and “-”,it won’t damaged torch and also can be run normally .
8.Power indicator for side switch ,when the light changed red ,it means you need to charge the torch or change batteries.Press side button long time for turn off,quickly press twice for Strobe mode.
9.B3104 is the first U2 high brightness freenis flashlight that use 26650 battery and with double switches .
Advantage of side switch:
1.Random switch modes you need, convenience and promptly.
2.Add to Electricity reminder,when the power is low,the red indicator will display.
Przybyła do Polski dość szybko, jednak okazało się, że nie jest zbytnio zgodna z opisem zamieszczonym w aukcji. Brakowało sznurka, a tryb maksymalny to jedyne 1.4A na dupce (więc daleko jej było do 1198 lumenów). Po kilku mailach odzyskałem jednak parę $. Oto ona:
Po testach i wyciągnięciu wnętrzności zapadła decyzja o modyfikacji. Zakupiłem driver 8xAMC nanjg105c 2.8A, diodę XM-L2 z binu U3, kolor zimny oraz szybkę z powłokami AR. Oryginalne szkło też niby miało powłoki, ale nie mogłem się doszukać charakterystycznej fioletowej poświaty (choć na oko bardziej przejrzyste niż zwykłe szkiełko).
Do dzieła!
1. Stary driver, 24 mm
2. Nowy sterownik wymagał (z racji mniejszej średnicy) dorobienia podkładki, na której mógłby się oprzeć, a bez której uciekłby pod samą diodę. Pomysł banalny, esteci pewnie będą krytykować, ale mi chodziło o funkcjonalność i full DIY :-)
Dwa druty miedziane o różnych średnicach, grubszy nawinięty na akumulator 18650, mniejszy na coś innego, co miałem pod ręką. Pasowały perfekcyjnie do siebie i do brzegów sterownika. Pozostało zalać je cyną i gotowe.
Niestety nowy driver nie posiada microswitcha, więc włącznik na korpusie pozostaje nieużywany. Czekam z niecierpliwością, aż towarzysz greg zakończy swój projekt i udostępni mi jeden sterownik (pospiesz się!) :-)
Mogę w sumie zamówić LD-34, bo i pasuje wymiarowo i posiada microswitch, nawet 3A w diodę leci, ale wolę poczekać.
3. Dioda. Przedtem XM-L U2 na gwiazdce, obecnie XM-L2 U3, zalutowana na NOCTIGON. Pod diodę pasta, niespecjalnie droga i o wygórowanych parametrach. Latarka ma duży korpus, a prądów ogromnych nie ma, więc grzanie się elementów jest w zupełności normalne.
4. Efekt końcowy.
Z racji, że jest to mój pierwszy mod nie przyjmuję krytycznych ocen :-)
Dzięki za wytrwanie.
Edit: tak to świeci (f 2.8, T 4s, WB)
Ostatnio zmieniony niedziela 15 lut 2015, 22:56 przez robak1989, łącznie zmieniany 3 razy.
michal1
Post autor: michal1 »
Fajny mod, chociaż sama latarka trochę za droga w porównaniu do eagle eye x6 BLF SE
robak1989
Racja, Michał. Jednak mam bzika na punkcie 26650 i było to chyba najważniejsze kryterium przy jej zamówieniu. Latarka akurat to też narzędzie w mojej pracy, a nie tylko hobby więc i ciut dłużej musi świecić.
Ciekawa latarka i gratuluję moda. Ten driver to chyba 105D (patrząc na rozmieszczenie AMCków). Zdemontuj ten moduł włącznika i wyrównaj ten stykowy element mosiężny na płasko :)
robak1989
Bocian pisze:Ten driver to chyba 105D (patrząc na rozmieszczenie AMCków)
Zgadza się, literówka.
Bocian pisze:Zdemontuj ten moduł włącznika i wyrównaj ten stykowy element mosiężny na płasko
Chodzi Ci o poprawienie styku na brzegach drivera?
Jacek318
Post autor: Jacek318 »
robak1989, chodzi o zeszlifowanie nierówności na mosiężnym styku od strony włącznika.
Pomiędzy refem a MPCB jest jakaś podkładka centrująca? A sam mod bardzo fajny.
Ostatnio zmieniony czwartek 05 lut 2015, 21:28 przez Jacek318, łącznie zmieniany 1 raz.
robak1989
No przecież...
Ciągle myślałem o tym drugim włączniku.
[ Dodano: 5 Luty 2015, 21:51 ]
Podkładki centrującej brak, ale zrobiłem to celowo, ponieważ dioda z padem zmieściła się idealnie w otworze i centrowanie było już niepotrzebne.
[ Dodano: 5 Luty 2015, 21:56 ]
Ktoś kiedyś napisał na tym forum, że reflektor ma niewielki udział w odbieraniu ciepła. Obalam ten mit. Właśnie plastikowa podkładka centrująca hamuje odpływ ciepła w górną części latarki. Gdy MPCB jest dociśnięte bezpośrednio przez reflektor to dopiero czuć po dłuższym świeceniu, jaki może być gorący.
