hej
dziś dostałem emaila od FENIXLIGHT
że zostałem wybrany jako tester
niestety nie tk45
tylko modelu ld15
ale dobre i to
opis lampki
"Features
●Two types of output:
- High output: 117 lumens (1 hour 40 minutes)
- Low output: 8 Lumens (39 hours)
●Max beam length: 49 meters
●Peak Beam Intensity: 596 candela
●Impact resistance: 1.5 meters
●Waterproof to IPX-8 standard
●Included accessories: key chain, lanyard
●Cree XP-G LED (R4) with lifespan of 50,000 hours
●Uses one 1.5V AA (Ni-MH, Alkaline) battery
●80mm (length) x16.6mm (diameter)
●21-gram weight (Excluding battery)
●Digitally regulated circuit, maintains constant brightness
●Reliable twist switch
●Capable of standing up securely on a flat surface to serve as a candle
●Made of durable aircraft-grade aluminum
●Premium Type III hard-anodized anti-abrasive finish
●Toughened ultra-clear glass lens with anti-reflective coating
