Features:
*Material: Aircraft Aluminum
*Bulb: 4*CREE XM-L U2 1A
*Brightness: 3500lumens
*Operating voltage: 9-12V (up to 15V)
*Power supply (Included): 6*18650/12.6V-4400mAh (2S-3P)
*Modes: High(100%) - Medium(50%) - Low (10%)
*Runtime on High:60-80minutes
*Built-in bike mount, suitable for 22-25mm handlebars
*Watreproof and shock proof switch with an indicator LED
*Low voltage protection
*Thermal protection
*Battery pack with built-in protection
*Dimensions (mm): 58(diameter) x 76(lenght)
*Weight: 450gr (head only)
Protection levels:
1.
The battery pack has a protection circuit that will cut-off when it's fully charged.
2.
When the temperature is high, the protection system will kick-in, which will turn the light to low mode, and flash at every 5 seconds.
You can ride faster to reduce the temperature with the help of the wind or you will have to use the bike light on medium or low mode.
3.
The low voltage protection (9V) will turn the light to low mode automatically, and flash 2 times at every 5 seconds, then it will cut-off after 3 minutes.
If you restart the light it will be off within 3 minutes again. If you insist to use it, the protection circuit on the battery pack will kick-in to work and cut off the power completely and there will be no light at all. Please be careful at this moment, or you will not have any light on your way home at night.
Ci co sprzedają 4 x XM-L za 1000zł , to albo spadli z byka , albo coś im się pomieszało w głowach i myślą ,że mając taką latarkę złapali Boga za nogi
